Image Credit – Gear Seekers
Gear Seekers has built up the XWORKS 70 xFrame open SFF case or, more accurately, frame. The XWORKS follows the traditional sandwich layout, and is made of extremely high quality aluminum. The build comes out extremely clean thanks to the internal spine of the case housing most of the wiring. Assembly is flat pack style, and you can install a up to a 3 slot GPU of infinite length into the frame. CPU cooling is a traditional heatsink and fan with a 40mm to 70mm height recommendation to stay within the frame itself. However, nothing is stopping you from putting a massive tower heatsink on the unit...
Continue reading...
