Log G-unique DiY stuffs \\G-stick 17cm 600watts help USFF dream come true\
guryhwa
G-Unique
Dec 23, 2016
164
962
1cm shorter than Gstick 18cm skyreach version:
as long as 17cm itx GPU or 17cm mITX MB,so you can place it beside GPU or MB,or front of MB,dc cable can be customed to lead out in end(5x4 side) or cover (17*5 or 17*4side)
size is 17cm*5cm*3.7cm,with M3 mounting on the ac-in side,use mr30 as ac-in socket,and mr30 to C6 conversion cable for ac cord cable,length of cpu cable,archdaemon plug cable,sata cables,pcies cable all can be customed made:
Mesfer
Hi . I have the s4m case with 3060 ti mini and i5 10600k can you please make an internal psu that about 500w for it 🌹
If yes . How long it takes and how much it cost?
