Log Future Ghost S1 build
Adi
Hello,
I am Adi and like everyone I have SFF bug.
I have always a laptop user, but I need some more power and don't want to spend 2500 EUR on Blade 15 Adv.
I am planning on Ghost S1 build with 5600x and EVGA 3070 Ultra.
I need your suggestion on CPU air cooler and if this GPU will fit?
I am thinking of Blackridge with Noctua fans.
Has anyone build the similar build? and I am not adding any tophat to make it as small as possible.
Plagueis
There's only one cooler you should consider for the Ghost S1 and that's the Noctua L12 Ghost S1 Edition – the cooler the case was designed around.
Depending on your motherboard, you could also go with L12S and bend the heatpipes a bit or go for any other alternative; however, seeing that the L12 GE is just $55 and can be easily bought, I don't see why would you go for Black Ridge instead.
Regarding the GPU fitment - "EVGA 3070 Ultra" is not nearly precise enough. If you're thinking about the 08G-P5-3755-KR – it should fit just fine.
