Log FormD T1 - Water-Cooled 3950x and NVLink 2080ti's
AP2
291
325
Finally decided to upgrade my 8700k setup and give AMD a try again - last time I had an AMD setup was socket 939/Opteron 175.
System Specs
Mobo: Asrock X570 Phantom Gaming-ITX/TB3
CPU: AMD 3950x
Ram: 16GB Corsair Vengeance LPX DDR4 3600 C14 kit
Drive: Sabrent Rocket 1TB Gen4 NVMe
GPU: MSI 2080ti OC edition (x2)
PSU: 1k GUnique Setup
NVLink: Quadro 2 slot NVLink
Riser: C-Paine T1 Specific Riser
Riser Cable: ADT-Link male to female
Watercooling Specs
Aqua Computer 2080ti Nickel Waterblocks
Aqua Computer 2080ti Active Backplates with Vision
Aqua Computer Cuplex Kryos Nickel with Vision
Aqua Computer Aquaero
Aqua Computer Double Protect Coolant
Watercool.de EPMD matte black tubes
Barrow Fittings
Noctua Chromax NF-F12
I have tons of Aqua Computer gear, but not sure what I'll use until the case arrives 8/3.
For the motherboard to run SLI/NVlink, it will need to have bios version 2.30 - mine came with bios 1.6. (thanks @DrHudacris for confirming this). Updated to 2.30 and both GPUs show up and everything is running perfect.
Since the both card are 2 slots, I decided to convert one of them to single slot and remove the extra display port reinstalled the stock cooler and it fired up with no issues. Pretty happy about that!
*More info and pics to come*
  • Love
Reactions: DrHudacris
DrHudacris
918
1,720
Looking forward to this build! I have questions and some tips.
-Unless I missed it, what radiator are you using?
-As you know the M.2 on the board is on the rear, and this is in a terrible spot. It gets pinched between the motherboard and riser and the backplate is right up against it. I actually slightly unscrewed the top motherboard mounting screws to give a little bit of room for the drive otherwise it was bending and almost touching rear of the motherboard. Be careful when mounting the board!
-Is the riser custom or one-off?! Very interested in seeing that !
Reactions: threestripevida
