Hello sff.network
Just posted in the intro section.
I've long been dreaming of building a pc and given the new gpus, forthcoming zen, and the imminent cyberpunk release, I figured the time is now.
Given that I've been wanting to do this for 20+ years I decided go straight for the abyss and plan the build around the FormD T1.
I've just started collecting components and have put together this spreadsheet which should, if nothing else, illustrate the silly amount of money I may well sink into this 9.5L void. I hope some of you take and use the spreadsheet to help you plan your own builds. Feel free to copy it, improve it (some sort of loop planning would be cool?), and disable the equations and remain in the dark about the financials.
Here is a consolidated list for those not clicking the above link
The planned build components were compiled after hours deep in the rabbit hole, especially those cooling bits, and referencing many builds here and on the sffpc subreddit.
Being a general wfh + gaming system, the gpu is central, and based on what look to be solid out-of-the-box thermals I'm trying to get my hands on a 3080 TUF and run it with the stock cooler until I want to tinker again and add a gpu waterblock + 2nd rad.
One question I have off the bat is how to get the EK ddc pwm pump powered? Would appreciate a link to a post I'm sure I missed somewhere.
I'm sure I've got more than is necessary things on the list and there's likely parts missing so please weigh in and wish me luck. Parts availability willing I may be up and running by the new year.
Cheers.
Chassis | FormD T1 |
Motherboard | Gigabyte Aorus Pro B550-I |
CPU | AMD ryzen 5 5600x |
GPU | RTX 3080 ASUS TUF |
RAM | CORSAIR Vengeance LPX 16GB 288-Pin DDR4 SDRAM DDR4 3200 |
Storage | WD BLACK SN850 NVMe M.2 PCIe4 500GB |
Storage | WD BLACK SN750 NVMe M.2 PCIe3 500GB |
PSU | Corsair SFX750 |
Cheers.
