Hey everyone - new to SFF-building and the forums. = )
So, I've been asked by a friend to make him a new gaming-pc - only thing is, this friend is also a... HOARDER!! And has a mild form of Autism, so his needs are specific - he's often got a lot of dust at his home (thinking I need to mod the dust-filters, perhaps add ventilation in the chassis to compensate) , since he has trouble keeping things clean. I'm making it SFF since he has limited space - I've done quite a bit of reading, but I'm still not entirely sure about my planned build, so if you whom are more experienced could have a look at my plans and let me know what you think, then that would be awesome.
He's also absolutely adamant that there must be a Bluray drive in the build, so that part is a must as well - I tried to find one that can do real 4K that's actually slim and on our market, but I'm not sure if this is the best bang for one's buck? (LG drive)
Budget: ~1500 Euro / 1600$
Build:
CHA: SilverStone Milo ML08
CPU: Ryzen R5 3600
GPU: Gigabyte RX 5700 XT Gaming OC
MB: MSI B450i Gaming Plus AC
RAM: G.Skill Ripjaws V 3200MHz 2x8GB (F4-3200C14D-16GVK)
SSD: Samsung 860 QVO, 1TB
ODD: LG BU40N (4K UHD, RW)
CU: Cryorig C7
PSU: Corsair SF600 V2 600W
I’m particularly concerned about the versatility and durability of the BD-drive (soo many formats out there…!) as well as the cooling-solutions – should I increase the cost of the build, by going for a partner-card instead of the reference-design on the RX 5700? Is the Cryorig C7 sufficient to cool a 3600?
I picked the 3600 specifically because it has a lower TDP than the 2700x, which would have been my pick otherwise.
The 5700 is a very power-hungry card, but with a bit of undervolting magic, I figure it shouldn’t be a problem. (the nVidia equivalent 2060 Super / Rtx 2070 non-super have a ridiculous price-tag in my region!)
All right, looking forward to your takes on my build, cheers!
EDIT:
I've changed the graphics card for the build - what impact will this have on thermals, et c? Is it even possible to use this kind of card in the Milo Ml08, without modifications?
Build:
CPU: Ryzen R5 3600
CU: Cryorig C7
EDIT:
