After wrestling with what case to use I settled finally on the Silverstone SG13WB. This was an affordable case ($69) that I felt will be forgiving as an entry point into SFF.
So with that (surprisingly difficult) decision down, I'm starting to refine components selections now I have a case to design around.
Here's my thinking...(btw this build is for gaming (1080-1440) and sometimes cad (work))
(also...if I should be posting pcpp links instead of just listing them, then apologies : )
CPU - Ryzen 5 3600 (lots of suggestion for this in the bracket, so this has informed my decision, but wonder if I should consider something stronger)
MB - GB X570i Aorus Pro WiFi
GPU - Zotac GeForce GTX 1660S TF
PSU - 600-650W (not sure if this is really an item to skimp on but figure something trusted like Corsair)
CPU cooler - NH-L9a (interested in AIO but figure L9a is a good starting point)
RAM - G.Skill Trident Z 2x16 DDR4 3200 (I understand 16MB is probably sufficient for games but indicators pointed to 32MB for multiple app switching and different uses, namely cad (Revit 2020) which will be for work at home. Happy to be convinced otherwise as the price point has a massive range.
HD - 1TB M.2-2280 NVMe (not sure which brand to run...any suggestions for a trusted brand?) Also extra 2.5" storage is probably easier on budget at this early stage than another ssd.
Build price sitting around NZ $2K
Instinct tells me this might be a bit CC but a good starting position with maybe some tweaking here and there. Keen to know what you think.
