I am so tempted to make a unibody STX case knowing it actually has that level of Hackintosh support. So just to be clear, AsRock has made it so you can just flat install OSX or is there still a lot of fiddling to be done?
its listed under their BIO downloads
"Support MAC OS X installation"
http://www.asrock.com/support/support.asp?cat=BIOS&Model=H110M-STX
this deskmini you update to that bio and stick the usb drive with Sierra on it with unibeast / multibeast on it and you are good to go.
The only problems ive run into but have fixes are (dual monitor support) (artifacting top left of the monitor)
I havent fixed these yet.
Heres the TonyMac thread
https://www.tonymacx86.com/threads/asrock-deskmini-110-issues.200939/
And youll want one of these as well
https://www.newegg.com/Product/Product.aspx?Item=N82E16856989002
my gripes is that the bluetooth module doesnt work with MacOS, I want bluetooth because there arent that many ports~ (I run 2 thermal printers off the deskmini) end game I want to use a BT keyboard and my MX Master or MX Anywhere 2.
Another gripe is that I had a G4560, in it before. I believe I saw a couple threads on TonyMac where they got G CPUs to work but its more work. So I basically took my extra 6700K and used that (no extra work) because the 6700 CPU was used in the latest iMac
Another gripe is that I didn't really know how to stick 2 OS's on the M.2 (which can be done for MacOS) So I have Sierra on the Samsung SSD and Windows 10 on the M.2
6700K / 16GB / Intel HD530 / Intel 600P 256GB M.2 / Samsung 850 EVO 500GB / Seagate Barracuda 2TB / Noctua NH-L9i / Intel 7260NGW Wifi / Bluetooth 4.0
It runs MacOS Sierra and Windows 10
The new macbook pro 2016 runs a AMD 460 (native drivers) so people have gotten 460s to work with a little fiddling.
