Extra tiny Dell video card - 4GB 940MX and MX150
thewizzard1
348
258
Update: Finally picked one of these up, and a laptop to come with it. Will be investigating pinout and voltages soon! I *hopefully* plan on making a m.2 adapter for this, if I actually get around to it.
Also of note: This uses the same connector (and likely pinout) as Dell's latest Pascal notebook modular eGPU offerings.
Windfall
2,117
1,584
Are you going to make a bite-sized eGPU with it, or mount it internally?
thewizzard1
348
258
First plan is to install it inside the 'almost correct' Dell it comes with, then figure it out, then have fun with it on an m.2 extension. Might as well slap it into a Type-C enclosure, but the problem will be getting the video from it out the other end. I'm not positive how well passthrough works over USB.
Reactions: Windfall
