Hi all. Selling my Sliger Console ITX case. It was purchased on 26th May 2020 for a project that never materialised. It's been sat dormant in the box since. I think it has been built in just once, tested, and then the parts removed.
Some things to add:
- It was purchased with the vertical base plate that will be included in the box.
- One of the screws that holds the PSU bracket in is missing. There are still two of the three present, but if the missing screw bothers you then you will need to source a replacement.
- Regarding the PSU bracket, the tolerances for the screws is very tight. It fits like a glove. It might require some patience to get everything 100% lined up.
- It didn't come with motherboard screws so make sure you have some.
- It has a riser included but said riser is "only" PCIe gen 3, as it's from 2020 when Gen 4 was still too new to be included.
- Case feet are stick-on ones and unused. The base plate includes it's own feet.
Thanks for looking. I'm not looking to profit on this, just move it on to a new owner that will utilise it. I paid 194Euro for it, and i'm willing to sink the delivery cost of moving it on to another person in the UK. If you want it shipped abroad, you will have to pay for that.
Hence I am asking £160 for it, subject to the above terms.
Some things to add:
