Hi all,
I'm currently awaiting delivery of my TG window M1. I'm thinking of doing a PETG custom loop with a 92 at the back and slim 240 in the basement. I'm just trying to put together a parts list and I'm currently stuck on a pump/res.
I really like the enermax neochanger 200mm but I'm concerned about the size at just under 20cm in length. Has anyone used, or considered using one of these in their M1 custom loop build? Will it fit? If turned sideways I'm concerned that there will be not enough clearance between the end of the res and the cpu block, and I'm sure it's way too tall to mount vertically. I will be 3D printing custom mounting for it, or just machining it out of a piece of ABS.
Any suggestions?
Any suggestions?
