Press Release: When an article is marked as such, it is posted verbatim from a Manufacturer’s text, and does not reflect the views or opinions of SFF.Network.
EK, the leading liquid cooling gear manufacturer, is announcing the availability of two high-performance liquid cooling solutions for the AMD Ryzen processor family based on the AMD AM5 socket. These single-socket AM5 water blocks are available in both the standard and the 1U-compatible format designed specifically for server racks.
EK-Pro CPU WB AM5 Ni + Inox
Being a dedicated workstation-grade water block for AMD AM5 processors, the EK-Pro CPU WB AM5 Ni + Inox water block features two standard G1/4″ threaded ports on its top. Built with performance, reliability, serviceability, and no compromises in mind, this enterprise-grade cooling solution is intended for desktops, workstations, and taller server racks. The water block’s top is CNC-machined from durable black POM Acetal, and the hold-down bracket is made of...
Continue reading...
