Hello everybody.
Just got new case E.mini H88 Pro for APU build with external power brick and hurry to share my impressions.
Overall quality is very good. No sharp edges, good paintjob, precise fit.
Made first measures with HDPlex DC-ATX 200W:
1) It fits but first you should cut off button/led PCB or you can't plug in adapter to ATX connector.
2) Stock HDPlex connector (Dell 7,4x5 mm) doesn't fit in DC port that is for 5.5 mm connector. So drill it out (this is bad way imo) or better replace cable for HDPlex and powerbrick.
Pics:
First attempt:
Needs some cable management inside.
ASUS B550i
Ryzen 4650G
Noctua NH-L9a+Wraith Spire fan
Crucial Ballistix 2x16 rev.B 36C16U4@4133CL16
WD Black SN750 1 Tb
WD Blue 3DNAND 2 Tb
HDPlex DC-ATX 200W+Dell 240W power supply
Pics:
First attempt:
ASUS B550i
Ryzen 4650G
WD Black SN750 1 Tb
WD Blue 3DNAND 2 Tb
