I have a first generation nr200p, and I'm hesitating to change (on a whim).
I have a 5700x3d, aorus 6800xt, and a SCYTHE FUMA 2.
I was thinking of looking for another box that could improve mine in some way, and at the same time try to put in some AIO 280/240 (even look for a box that allows a 360 aio and as small as possible), do you recommend any box to look at? I've looked at the Lianli a4-h20, the nr200p V2, or what else can I look at or do you recommend?
