Desk size vs SFF case size
tinyitx
2,279
2,338
If your SFF case sits on your desk (ie the main working desk which you use daily), what is the size of your desk and the footprint of your SFF case? I am just curious to know how much space does a SFF case occupy a SFFer's main desk.
My desk is 153cm x 69cm.
My case is a test bench and is not SFF. Its footprint is 360mm x 270mm.
So, it is about 9% of the desk surface area.
I am going to build a ITX test bench (230mm x 190mm) in Q4 and will reduce the % down to 4.
5,939
4,951
My complete desk is 240cm x 80cm, which has various PCs on there. The area I use for my main PC that doesn't include the other builds is about 160cm x 80cm (128 dm²), of which the Cerberus X is taking 172mm x 358mm (6,16dm²) according to specs. So it's about 4,8% in volume in my situation.
dm² = square decimeters
0,1m = 1dm = 10cm = 100mm
0,01m² = 1dm² = 100cm²
Reactions: TheHig and tinyitx
Solo
894
1,500
My desk is literally made from a standard 8ft door. It's way too god damn big for what I like to have on it lmao.
Reactions: TheHig
BirdofPrey
Standards Guru
Sep 3, 2015
797
493
I don't have the dimensions handy, but my desk is an Ikea Galant (the corner one), so it's not the most massive desk you've seen, but isn't exactly small. I run 3 monitors, though, so I do need the space.
PC's actually on the floor, though, which is probably a bad idea.
Elerek
228
165
My desk is 60"x30", but it has about a 6" deep curve cut into the front.
My pc is a vertical NFC-S4 mini, so it takes up 2.5"x8.85".
I've got a 27" wide screen monitor, a 2.1 sound setup (sub is behind the monitor), and a full size keyboard. I'm getting a split tenkeyless keyboard soonish though because the full size just takes up too much space and I never use the numpad.
I wish I hadn't gotten a desk with a curve cut into it though, I have to sit closer to my monitor than I'd like to.
Reactions: tinyitx
tinyitx
2,279
2,338
Even though the footprint of a SFF case is usually small, I still would prefer a tall slender SFF case over a low sitting long SFF case as the footprint of the former is even smaller.
TheHig
951
1,171
Door from your local home improvement store and ikea legs make some of the nicest diy desks around! Also galvanized threaded pipes work well for making desk legs for your door.
I rock some 2x4s and salvage plywood in the classic “L” shape myself.
Two PCs , monitors , peripherals. S4M and Cerberus x.
7,413
Desk = 0.72m²
Case = 0.03m² , ~4%
I'm considering standing the DeskMini vertically, which would mean 0.012m², or ~2% of my desk space.
My Deskmini sits under my monitor (which is mounted on a monitor arm).
Reactions: Phuncz and TheHig
Windfall
2,117
1,584
This thread is like the holy grail of sffness. When you are worried about using 4% vs 2% of your desk space, you know that you really are dedicated!
