I searched for hours trying to find who makes the chips in the Kingston HyperX ddr4-3200 SODIMM ram.
Crucial is Micron
I own the G.Skill DDR4-3200 (2x8GB) kit and those are Hynix AFR. I am assuming that the (2x16GB) kit is also Hynix AFR.
The Kingston HyperX has a CAS latency of 20 which is lower then Crucial (22) but Higher then G.Skill (18) at 1.20V.
Was just curious what the Ryzen DRAM Calculator had to say the different manufactures and their SODIMM chips at 1.35V. Accourding to the Calculator Hynix CJR, Samsung B-Die, and Micron A Die are those manufactures best chips for low voltage, High Frequency, Low CAS, combinations. No Clue if those even exist in the format though.
Anyone own those kits and are able to give specifics OR can point me in the right direction on acquiring the information?
Crucial is Micron
The Truth about Memory Manufacturers
Learn the difference between true memory manufacturing companies and organizations that only assemble the modules & why it's an important distinction.
www.crucial.com
Crucial 32GB (2 x 16GB) 260-Pin DDR4 SO-DIMM DDR4 3200 (PC4 25600) Laptop Memory Model CT2K16G4SFD832A - Newegg.com
Buy Crucial 32GB (2 x 16GB) 260-Pin DDR4 SO-DIMM DDR4 3200 (PC4 25600) Laptop Memory Model CT2K16G4SFD832A with fast shipping and top-rated customer service. Once you know, you Newegg!
www.newegg.com
G.SKILL Ripjaws Series 32GB (2 x 16GB) 260-Pin DDR4 SO-DIMM DDR4 3200 (PC4 25600) Laptop Memory Model F4-3200C18D-32GRS - Newegg.com
Buy G.SKILL Ripjaws Series 32GB (2 x 16GB) 260-Pin DDR4 SO-DIMM DDR4 3200 (PC4 25600) Laptop Memory Model F4-3200C18D-32GRS with fast shipping and top-rated customer service. Once you know, you Newegg!
www.newegg.com
HyperX Impact 32GB (2 x 16G) 260-Pin DDR4 SO-DIMM DDR4 3200 (PC4 25600) Desktop Memory Model HX432S20IBK2/32 - Newegg.com
Buy HyperX Impact 32GB (2 x 16G) 260-Pin DDR4 SO-DIMM DDR4 3200 (PC4 25600) Desktop Memory Model HX432S20IBK2/32 with fast shipping and top-rated customer service. Once you know, you Newegg!
www.newegg.com
