dancase a4 sfxv4 new build, help
Plaklijm
164
87
Hey guys,
im planning on building my new pc in the dancase a4 v4, but I have a few questions before i dive in and buy everything.
1. Can you mount the asetek 92mm aio in the back, and a 92 mm fan in the front under the mb? because i want to buy a ryzen 3000 cpu, and people recommend cooling for the vrm and the chipset, and it just lowers the overal temps, and if it fits, do i mount it as a outlet or an intake, because i want the aio as intake with pull.
2. I think it fits, but can you mount a ssd at the front, and because the underside of the case is filled with fans, can you mount a ssd anywhere else in the case? because i saw a top ssd mount, but where is this mount, and does it fit?
3. and just in case, does the gigabyte geforce rtx 2070 gaming oc fit?
hope you guys have the answers for these questions!
91Mackmr2
54
Hey guys,
I don't believe there is a ssd mount on top, I know there's one in the front and below the psu if you were not using the asetek. Actually you can fit two under the psu if air cooled.
