I consider this a one-off unless there's more interest in making a build like this one. But this one's pretty custom for the case. That case will be based heavily on my Project Thin-X case, but modified to fit a full-height card in a single slot form plus internal PSU.
After drawing some inspiration from @guryhwa's case (just look at it) it feels even more possible for me to sandwich together a regular mini ITX board with a full-height GPU. He went all out with a Vega 56 Nano. I find it easier (and cheaper) to try it out with a GTX 1050 Ti. Less power cables, and less thermal management to worry about. The case will be roughly the same size. It's easy to make it into a single slot GPU by removing the stock cooler. Plus I will stuff a MeanWell PSU inside for that brick-less flair.
Here is the motherboard and CPU cooler I plan to use. Gigabyte H110N-Wifi and Zalman CNPS2X:
The power supply, GPU and CPU are the other major components I need. The Zalman cooler is 27mm tall which I set as the maximum height this could support. It's just as tall as the RAM sits inside the board. I could use other similar radial coolers that are shorter, but they wouldn't cool as well as the Zalman.
I am not able to start planning and building immediately but will take time over the weeks to get the first parts and test configurations.
