The Crono Labs C1 is a portable computer case that is compatible with high end hardware. It mounts a monitor so it can be easily moved using the included removable carry handle. It is aimed at people who want to retain control over the components in their PC (unlike a laptop), but still want to be able to bring it with them to LAN gaming events, or even to and from work.
Hardware compatibility:
GPU: Up to 10.5" (with included PCI riser)
Motherboard: mITX
Fans: None, all components vent directly out
Drives: 2x 3.5" drive bays
CPU cooler: Under 55mm in height
PSU: ATX
Other features:
Monitor tilt and height adjustment
Power switch and USB ports on the base for easy access
Removable carry handle
Dust filters
Aluminium construction
We have just launched on Kickstarter and someone on reddit said you guys might appreciate it, any feedback or support would be appreciated! If you want to support it or get more information, the campaign can be found at: kickstarter.cronolabs.com
Note: Overwatch is photoshopped onto the screen due to lighting issues
Motherboard: mITX
PSU: ATX
Other features:
Dust filters
