So I'm a complete noob to these forums, got here from the SFFPC subreddit.
I've been thinking through a melting pot of ideas since I saw a few cases I really liked - but none of them had the configuration I was looking for, or were in stock, so I decided to 3D print my own (and pick up 3D modelling skills in the process, as a bonus.)
Those ideas being:
Those ideas being:
- The modular bracket of the FormD T1
- If a GPU has a larger or smaller slot size, you can move the bracket up and down the case. It also allows for more cooler space.
- Attachable stands for tower configuration
- Only downside is the cables would be bent when in tower mode, but it's alright.
- Support for 2x SSDs (if possible) or 1x HDD
- This is the boldest part, I don't know if I can fit an HDD or the SSDs in, then not burn the case down. HDD would be preferred, I really need those +8TB.
- 7-8L format
- Just want something as small as possible, going after something similar to the Velka 7. (Velka 8?) Ideally it'd fit in my backpack.
- GPU support would be limited to under 302mm.
- Otherwise - a normal SFF case with good airflow, etc etc
