Cooling Corsair H60 vs H75
Jace
24
30
Hey! Does anyone know if there is any differences between Corsair H75 and H60 other than H75 having 2 x 120mm fans and braided tubing? Any differences in pumps? And I'm talking about the 2018 versions for both. I am going to use the cooler with single Noctua NF-A12x15 fan in Dan A4 SFX v3 case with Ryzen 7 2700X.
Scott
29
I looked at this once in the past and I didn't find any difference other than the H75 having 2 fans. Just go with the cheaper one.
Only annoying downside is that I don't think the H60 comes with enough screws to mount 2 fans if you ever want to add one in the future in a different case. I had that problem with my H50 when I added a second fan to it. Had to go find compatible screws to make it work.
Jace
24
30
Thanks, I went with the H60.
Well I have compatible screws for the Noctua fan and the stock fan has it's own screws so I think I'm set even for some other case. And there is no shortage of hardware stores in my area if something goes wrong :D
