News Coffee Lake variant including on-package Vega GPU
Combines a Core-H CPU part (45W) with an as yet unspecified semi-custom Vega Polaris GPU plus at least one HBM2 stack. Uses Intel's EMIB rather than a monolithic interposer, but appears to be doing so just for the GPU-HBM link rather than for the CPU-GPU link judging by the mockup image provided by Intel, which could just end up being PCIe x16 for simplicity (using an existing interface both GPU and CPU already posses).
All signs point to this being an "Apple wanted us to make it" SKU like the Iris Pro line, but there's a non-zero chance it could make its way to other products too. Probably in the form of NUCs rather than as installable LGA chips.
Alternate headline: today's weather in hades; heavy snow with chances of hail.
5,947
4,952
These have a targeted 100W TDP if I remember correctly reading that somewhere. That's not something easily done in a NUC-sized case who use 15W TDP processors I believe. Though this would be more than perfect for 1-3L sized computers like VR backpacks or living room PCs.
whum
47
You guys can rest assured that big SFF boosts are coming in 2018 and 2019 because I just spent my upgrade budget for the next 2-4 years and I always gamble wrong and buy my PCs right before the big changes hit the market. XD Having said that this is pretty exciting news. I can't wait to see what 2018 has in store for small form factor and when Intel inevitably buys AMD we will really be on our way. XD
AleksandarK
/dev/null
May 14, 2017
703
774
Manufactured on 14++ HP process(at Intel!), which should, in theory, give it adventage over Glo Fo manufacturing process. This one is intended for High-Performance(HP). Maybe the Polaris GPU could be clocked way higher than "regualar" model.
Also i am wondering two things:
1. At what speed EMIB bridge runs at? I suspect it is near infinity fabric, maybe better?
2. This could "eat" some of NVIDIAs market share, so it is natural that they try to respond. Just when and with what. It is not like they can use ARM based CPU.
Maybe ARM will release a desktop core(for laptop use) capabe of x86, AVX, SSE(i only know Intels ISAs) instruction set.
The more i write about this, it makes more sense.
jØrd
S̳C̳S̳I̳ ̳f̳o̳r̳ ̳l̳i̳f̳e̳
sudocide.dev
LOSIAS
Jul 19, 2015
818
1,359
Do you have a link for this? Everything ive seen so far seems to suggest GloFo will be fabbing the AMD GPU's and then shipping the finished dies to Intel for package integration.
I've been wondering about this too, is it a clocked part or just a slightly better interposer. I havent yet had oppertunity to read up on this, anyone have a TLDR?
Given the dominance of Windows in this market and the utter catastrophe that was WindowsRT im not confidant it will happen any time soon. I doubt ARM will ever put out anything x86 compatible (either through binary translation or otherwise) ever, ignoring technical, licensing and legal minefields its just not in their market interests to do it & would negate their key USP's. IIRC they do have some ISA extensions that have similar functionality to some of the x86 ones though, NEON comes to mind & im pretty sure they have something similar to AES-NI as well as some others.
AleksandarK
/dev/null
May 14, 2017
703
774
Everyone has OP, but i think that Bits and Chips is reliable source. Their predictions are proven.
I didnt read about it specs either lol. Will do tommorow if there are any articles written.
Btw,
EdZ
Virtual Realist
1,578
2,107
EMIB is basically all the advantages of an interposer (putting your interconnect in a silicon wafer with high-density chip connections) without the disadvantages (cost due to reticle-bustingly massive sizes, needing to use complex Through-Silicon Vias to connect from the chip to the substrate). There should be no difference in link speed between EMIB and a full-package interposer.
'Infinity Fabric' is a PCIe-like protocol for linking devices. EMIB is a PHY-layer technology (or lower still, it's a vehicle on which you can fab your PHY layer). You could run Infinity Fabric, DMI, PCIe, UPI, HBM, etc over it if you implemented the PHY links on-die to use those protocols over a silicon bridge.
EdZ
Virtual Realist
1,578
2,107
Even with only a ~45W desktop CPU, putting a 100W GPU into the same package is going to be a real challenge for cooling.
whum
47
It looks like it is Mini-STX. Maybe Intel is pushing their form factor with this new product.
I need to try and find the release to confirm it, but I distinctly remember hearing Intel was making a successor to the skull canyon NUC but essentially rebuilding the form factor 'from the ground up' or something similar to that. I feel like this leak might confirm some very exciting changes. I heard endless woes of heat and noise from the 2016 skull canyon NUC. I always wanted to buy one myself, but I agree with those who feel that they might have tried to push the form factor too small. If they are going to expand it just a bit with an stx like this, and maybe get a little closer to the zotac boxes AND drop in some intel-vega goodness? Well that is going to make 2018 very exciting for SFF.
CC Ricers
2,234
2,557
Skull Canyon NUCs felt too weak for gaming performance. I never saw much value for the price of the Iris Pro chips. They might make it a bit larger this time to accommodate the cooling.
Reactions: Biowarejak and whum
