Hi all,
I'm attempting my first basic case mod and could use a little input. I really dig the inwin chopin case for its size, but I'd like to be able to put some higher end, higher TDP cpus in it, and for this the 150W stock power supply just doesn't cut it.
So I started looking around for replacement PSUs, but since the stock one is such an unusual shape, I could hardly find anything that would fit. I'd also like to keep the system brick-less, since it's such a great perk of the chopin compared to other SFF cases of similar size.
Enter the HDPlex 200W NanoATX combo. It's just the right size that I managed to squeeze it in without cutting up the case too much, and comes with an internal AC-DC adaptor brick. Perfect I thought - so I went for it and here's my current situation:
The HDPLEX 200W AC-DC is front and center, and it pretty well in the space where the stock PSU was, and you can see the DC-ATX nestled snugly in the bottom right corner.
I used a 24 pin extension cable, and the 6 pin cable routes through the back. Pretty darn cool I thought - granted I've never attempted anything like this.
But here's my problem, I'm so close, yet so far - It doesn't look like I have room for the C14 to JST ELR-03V to fit through the back:
It's pretty heartbreaking that it's come down to this one issue where all I needed was just a few extra centimeters..
The C8 to JST ELR-03V option will probably fit better, but I'm unsure what the pros and cons of using this 'smaller' plug would be, if any:
Thanks for your time and I'd appreciate any feedback on how I could have gone about this more elegantly, or what my next steps should be.
