Where do I get a C8 connector with ELR for HDPLEX ac-dc
bran
70
So hard to Google .I need a C8 female connector and a female ELR connector for me HDPLEX ac-dc. This is for a brick less s4m build.
John Morrison. Founder and Head writer SFF.N
Editorial Staff
Moderator
6,007
rook
69
74
If you're buying straight from hdplex, isn't this style of connector included with the purchase? The c8 connector on the nfc one does look shorter though.
bran
70
You may need to make your own, alas. The choice of ELR connector is pretty uncommon in products with the C8 connector - usually the C8's are reserved for consumer electronics with soldered wires :(
However, you could wait until @Josh | NFC has the prebuilt ones back in stock: http://nfc-systems.com/shop-all/fs5yyuelcpkccl596azgxv15m6fv9r
Yeah I have figured out I can get a similar C8 from Mouser, even if it won't have perfect fitment. But come on this ELR connector is impossible to find.
Been watching the availability on Josh s sirs closely as well .
Choidebu
"Banned"
Aug 16, 2017
1,163
1,148
I start to think I'm too hacky that first thing I do is to just cut the provided cable and splice em. Like, ain't got no time hunting down connectors...
