CPU Change enclosed Top Fans from blow-in to blow-out ?
Bullz
42
I tried to remove the grille in front of the fans that is attached with the screws. I have not managed. Actually, the enclosed fans would replace the same by 2 ARCTIC P12 PWM PST I have lying around here only I do not know how to mount them now.
The coolers are mounted so that they blow in air and I can't unscrew the grille and I can't turn them over and so I can't mount them because the airflow direction is wrong
https://ibb.co/kKXbvHR
