- Apr 4, 2016
- 1,729
- 1,672
Hi all!
So as you all know, I have received my Firewolfy's MI-6 a few days ago, so I'm gonna do a build log now! (And since I'm down with stomach problem, this will a progressive WIP in multiple parts). I'm following the build order provided (included in the package), so hopefully I won't get any nasty surprise.
This is my first case which is a community project, also my 2nd SFF case (the previous one is Silverstone SG08). So yes, this is actually more of transferring old hardware into new case
You can see from the pics that the version I order is the one with front IOs. I also order the tool-less HDD bracket.
I'm not going through the technical specs.. You guys can see it here:
- https://smallformfactor.net/forum/threads/ccd-mi-6-case-performance-in-less-than-7l.1091/
- https://www.casebycasedesign.com/
What's in the box
The case, MI-6 badge, extra anti-friction tape, cap for rear outlets, extra screws, cable ties (not in the picture: instruction card and invoice). Simple zip bag packaging & clearly labeled. No-frills & just works. I like it.
The case itself:
Let's get started!
CPU + Motherboard
I started by removing the cover (side & top, duh). Next, install the motherboard. Mine's not the best in terms of layout. I purchased that knowing that the CPU socket location would accommodate the NH-L12i. BUT I had never thought that they put the USB 3.0 header so close to the CPU socket (I had to purchase a flat USB 3.0 header cable from modDIY in the end). I didn't remove/re-paste the NH-L12i, I just removed the top fan so it can fit (I hope.. fingers crossed).
Looking good so far:
Hint: leaving the GPU riser unattached gives you more room to work with. Attach it later AFTER you're done attaching all cables onto your motherboard. Also, some of you may have ATX header at the bottom part of the mobo, nearby the PSU.. that'll be a bit tricky but CAN be done.
PSU
Next, I installed the power supply. Man, this SFX psu is small & lightweight. On the right, as a comparison, is my previous ATX PSU.
Hint: I found out that I had too many cables dangling into the PSU area, so I put the case upside down instead. Thank God for gravity. It helped Newton, now it helped me.
And it sits nicely there:
All went well so far!
Processor: Intel i5-4670 non K
Motherboard: Asus H87i-Plus
RAM: Kingston Value RAM 8GB (and super low profile)
SSD: Samsung Evo 850 500 GB 2.5" SSD
HDD: Western Digital Black 500 GB 7200 RPM
GPU: Zotac GTX 950
PSU: Corsair SF450
GPU: Zotac GTX 950
PSU: Corsair SF450
What's in the box
The case itself:
Let's get started!
CPU + Motherboard
PSU
