Do I have to cut the GPU cables? I don't know how to do thatYes, I have that psu with a 5700xt on the ncase m1. I have to warn you though that the psu cables will push the gpu down, so you will have to look for a support for the gpu. In my build I have a dual rad setup, and the gpu block rest on the lower radiator fitting so it is perfectly horizontal.
Also I had to cut the gpu wiring and made myself some custom 24 pin cable because there are too many cables down there... In my opinion, if you already have the psu, go for it, you can make it work. If not, buy a sfx size psu, I also have a corsair sfx 750w psu on another computer, and I tried it on the Ncase.... everything much more simpler.
No, you don´t have to, but take in mind that cables are a bit too long, also 24 pin is a bit too long, and given the psu itself is a bit too big... everything sums up, and it fits very tight. It´s not something obligatory to do, but it helps. You will have to tidy everything very well, and even then, if you had use a corsair sf750 it would fit nicer
I noticed you have your fan facing inwards, does your side radiator exhaust hot air into the psu? if so, arent u worried about the high operating temps?yes, here you can see that the plugs are so close to the backplate...
Dropbox - File Deleted - Simplify your life
www.dropbox.com
So your PSU fan is facing inside the case, and your radiator fans are exhausting air. But that means the 2 fans are opposing each other?Those fans are exhausting air, and the side ones are also exhausting air. That way I may not have water temps as low as others, but everything else is cool (vrm, chipset, psu, m.2ssd, ram... ) And I believe that´s good for reliability and overall stability.
Well... I´m doing an experiment with a 60mm side radiator, (hardware labs gtx) and te psu without fans and also with no "shroud" I´m monitoring temps and trying to see if this has any benefit. But this is another story, just tinkering. It´s working fine with stress test so far with 570 w of power consumption (5700 xt overclocked and 3950 x) but I see no improvement in temps over a regular psu and a hardware labs gts on the side... unless I max out the fans, and then is when this big radiator shines.So your PSU fan is facing inside the case, and your radiator fans are exhausting air. But that means the 2 fans are opposing each other?
www.dropbox.com
Any way, when I use the regular psu with a fan and everything I put the psu the other way round with the fan taking cold air from the back of the case
