C13/C14
HeroXLazer
707
476
Where can I get a screw in C13/C14 screw in extension. I need to take the power cable from the PSU to the back of the case. Where can I get it?
KMPKT
3,382
5,936
Mouser or Digikey are both great places to source those sorts of parts. I personally use Digikey because their delivery is insanely fast (often within 48 hours).
Arboreal
818
814
if you mean something like the one on the NCase Accessories page (use the drop down menu), IIRC you can get them (not sure which orientation...) from Silverstone as they use them in the SG08/9/10
Arboreal
818
814
Yes, that's the one. You'll need to heatshrink it after soldering, with that voltage going through it. The inner engineer is not strong on thread sizes by eye, but maybe M4 countersunk screws would be what you need to put it on the back panel.
HeroXLazer
707
476
Okay.
