G-Unique Plug&Play unit power connector mounting solution
1461748123
489
1,068
Hi guys! I'm finally back!
After I post in this thread last week saying that I'm getting better, I got sick again to the point that I need to go the hospital to get injected by intravenous infusion for several days. Now I'm fully cured and hopefully won't get sick in a short term... :p
Okay lets get into the topic.
There are two solutions on mounting the power connector for customer that ordered the G-unique units higher than 220w.
The first one is a standard C13 mounting solution:
It has the exact footprint as the normal C14 panel mount connector.
The other one is smaller in size:
This is basically the middle part of the C14 mounting solution. It is smaller in size so it should fit the sff theme pretty well.
Hope this will help you guys out! If you have any question, feel free to PM me. Now I have to deal with tones of un-reply emails and pms.. :p
5,827
4,902
Good to hear that you've recovered, it sounds very serious ! Well done on that C14 connector replacement ! Black screws would be a nice "upgrade" ! The second version seems to be better aesthetically, but it might have all of the screw holes too close to eachother on the PCB to be sturdy ?
