Hello SFF maniacs
I assembled a PC with a 3070 Funders Edition, and an ideal GEEEK C2 case for it with a volume of 7.3l
In terms of the quality of the case: four stars, the chassis is strong but the processing could be better, it is easy to scratch the components, and it’s still hell to assemble in it, the plastic lining is also embarrassing, but in general the geeek c2 is very good
There are no problems with purge, there are perforations on the walls, as well as 2 fans can be placed both above and below, with a small gpu undervolt, the temperatures are wonderful (see screenshot of cyberpunk at ultras at 2k)
Specs:
Colorful CVN-B660
i5 12400f
RTX 3070FE
32GB Ballistix
2x M2 + Sata
Cooler Noctua NH-L9i-17xx
Case fans Noctua 92mm 4x
PSU Flex Enchance enp-7145 450w gold (sata cable shortened)
Raiser ADT 180mm gen4
Dimensions 268x220x125, fully assembled it fits into NR200
I would like to replace the acrylic walls with wood or metal, do you have any ideas on how best to do it?
Specs:
Colorful CVN-B660
i5 12400f
RTX 3070FE
32GB Ballistix
2x M2 + Sata
