Are you using World.taobao.com? - I think it'll still show in Chinese because most of the sellers are only posting in Chinese. One option is to use Google Translate on chrome, it's not super accurate but it works well enough.
One issue with Taobao is, the sellers are often very stupid. Here they expect you to contact them through the taobao chat service, and if you don't you have no idea what you will actually receive. I've had several sellers I thought tried to stiff me but I found they basically think if you don't contact them directly it means you don't care what you get so they'll just send you anything.
That said, many "good" sellers will contact YOU when you order something to confirm the order. If you don't speak Chinese this can be difficult but I have found some of the boutique sellers speak good or at least decent english. I strongly suggest you check out Sunmilo as I feel they have good service, are open and honest with you about buying stuff. They'll give you the date they will ship your case and they ship it on that date.
https://sunmilo.taobao.com/
prices are around $110-$170 for Sunmilo cases
I think they speak English - I might be wrong but if you are interested in their cases and have some trouble just let me know and I can try to help.
I found another case that was really cool called "Arcube" - I tried to order in January but the seller cancelled the order, seems he can't make the case very fast and has a very long backlog. The seller for this one does speak english.
https://shop131278021.taobao.com/sh...a230r.1.14.5.JCokBm&user_number_id=2657403360
Both of those cases are custom builds and you need to specify what features you want. Taobao doesnt really allow them to show what they offer in terms of features so it's best to ask them what they can do and what options they have. If you tell them what you're building they'll usually give advice and suggestions.
You could also try the Primo P115, which I have. It's about $75 and high quality. I put a review on my website:
http://robspctech.com
I'll give you some links for other Taobao cases which I found were very cool:
Hauteware Black Angel :
https://world.taobao.com/item/39186030201.htm?spm=a312a.7700714.0.0.4aeOEy#detail
Unicorn:
https://world.taobao.com/item/523845809710.htm?spm=a312a.7700714.0.0.kXqLKg#detail
SKTC Q1 - (basically a Raijintek clone) -
https://world.taobao.com/item/522605381425.htm?spm=a312a.7700714.0.0.kXqLKg#detail
