LZX-10 Alternate Front Panel with 140mm Arctic P14 Front Case Fan Testing
CPU-Z Stress Test & Unigine Valley Ultra Settings for 10 minutes
Aorus B550 ITX MB; Ryzen 7 5700G; 32 GB Corsair LPX 3200 RAM; Metal block over NVMe drive not installed;
Evga 3060Ti XC Graphics Card – Self Regulated
Thermalright Silver Soul 135
CPU & Case Fans PWM 100%
Front Intake, Rear Exhaust
Noctua NT-H1 Thermal Paste
Room Temp 21C;
Temp Sensor TZ10 read 16.8C on all test runs;
I finally installed the I/O panel for extra front/side ports. This is very well thought out as the connectors are on a separate circuit board with individual plug in cables. You need only connect what you intend to use. Only one USB 3 header and cable is required for 2 USB type A and one USB type C ports to be active. This is a perfect arrangement for the Aorus B550 motherboard that has only a single USB 3 header.
I obtained two additional front panels: one with 14 slots instead of the standard 10 slots, and one with a cyclone vent. In my initial testing I noted a whine when the front intake case fan was used at higher RPM - in particular with a 140mm fan. This was reduced somewhat when an Arctic P12 fan was substituted. You will note below that there is little temperature difference between any of the panels when using a 140mm fan. I thought there would be larger temperature and noise differences between the slotted panels. As to noise, I have no db meter, but both the 10 slot and 14 slot panels both have a whine that begins above 1190 RPM / 66% PWM with the P14 fan, that continues to increase up to maximum RPM. I noted no real noise difference between the 10 slot and 14 slot panels. However I did notice the whine was more distinct with both slotted panels when the nearly solid GPU vent only top panel was installed instead of the fully vented top panel. The cyclone front panel has no whine, but a lower pitched hum at higher RPM above 1190 RPM. The cyclone vented front panel also seemed to produce a bit more noise with the GPU vent only top panel. I estimate that when the fully vented top panel is installed, the front fan can run 10% faster to reach the same noise level as the GPU vent only top panel.
If you like the fully vented look, the 14 slot front panel matches vey nicely with the fully vented top panel.
The cyclone vent looks OK to me but I find the front panel a bit bare with just that vent. I would add 10 short slots on either side of the cyclone vent to match the slots on the other panels if I was to order this again.
As to reducing front intake fan noise at higher RPM, a solution might be to mount the front fan with 5mm spacers to inset the fan further inside the case, as there is enough depth to install a 30mm thick Phanteks T30. Anyone know where I can obtain 5mm longer self tapping screws and spacers?
CPUID HWMonitor Readings:
CPU Cooler | Thermalright SS 135 | Thermalright SS 135 | Thermalright SS 135 | Thermalright SS 135 | Thermalright SS 135 | Thermalright SS 135 |
GPU | Evga 3060Ti XC | Evga 3060Ti XC | Evga 3060Ti XC | Evga 3060Ti XC | Evga 3060Ti XC | Evga 3060Ti XC |
Case Top Panel | GPU Vents Only | GPU Vents Only | GPU Vents Only | Fully Vented | Fully Vented | Fully Vented |
Case Front Panel | 10 Slots | 14 Slots | Cyclone Vent | 10 Slots | 14 Slots | Cyclone Vent |
CPU Cooler Fan | TL-D12 Pro-G | TL-D12 Pro-G | TL-D12 Pro-G | TL-D12 Pro-G | TL-D12 Pro-G | TL-D12 Pro-G |
Front Case Fan | Arctic P14 | Arctic P14 | Arctic P14 | Arctic P14 | Arctic P14 | Arctic P14 |
Rear Case Fan | Noctua A9x25 | Noctua A9x25 | Noctua A9x25 | Noctua A9x25 | Noctua A9x25 | Noctua A9x25 |
Temp Sensor 0 Max | 52 | 52 | 52 | 53 | 53 | 52 |
Temp Sensor 1 Max | 45 | 45 | 43 | 45 | 45 | 44 |
Temp Sensor 2 CPU Max | 70 | 69 | 68 | 69 | 69 | 69 |
Temp Sensor 3 PCI Max | 21 | 21 | 21 | 21 | 21 | 21 |
Temp Sensor 4 Max | 45 | 45 | 44 | 46 | 45 | 45 |
Temp Sensor 5 Max | 52 | 53 | 52 | 53 | 54 | 53 |
CPU Fan Max RPM | 1923 | 1917 | 1923 | 1923 | 1912 | 1928 |
Front Case Fan Max RPM | 1683 | 1610 | 1650 | 1610 | 1618 | 1630 |
Rear Case Fan Max RPM | 2014 | 2008 | 2008 | 2008 | 2033 | 2033 |
CPU Pkg Max Temp | 70 | 69.1 | 68.8 | 69.8 | 69.1 | 69.4 |
CPU Pkg Max Wattage | 57.35 | 58.22 | 59.46 | 58.57 | 60.44 | 58.56 |
NVMe Top 980 Pro Temp | 46 | 46 | 45 | 47 | 47 | 46 |
NVMe Bottom 970 Evo+ Temp | 50 | 51 | 49 | 51 | 52 | 51 |
GPU Max Temp | 69.3 | 69.6 | 70.4 | 69.3 | 69.3 | 69.1 |
GPU Hot Spot Max Temp | 80.3 | 80.9 | 81.5 | 80.2 | 80.2 | 80.3 |
GPU Max Wattage | 191.22 | 189.12 | 194.03 | 196.31 | 193.51 | 192.78 |
GPU Fan Max RPM | 2070 / 2075 | 2087 / 2093 | 2124 / 2121 | 2069 / 2070 | 2073 / 2075 | 2069 / 2071 |
