Introducing Bonsai
Built with the environment in mind, its entire outer shell is made purely of bamboo. Eco-friendly, size, performance and elegance were the main inspiration behind Bonsai.
Aside from using bamboo, material minimalism was considered into the design. Four pieces of material complete the case (excluding fasteners and brackets).
Craftsmanship and quality are very important to us. All bamboo production is done in-house and is hand finished. Bamboo is both CNC milled and laser cut. The vent patterns are randomly generated based on Voronoi diagrams, making each case one of a kind. The idea was to mimic cells and embrace a more organic look while making each case unique in its own right.
The dimensions (excluding screw extrusions) are 5.25”x7.075”xx9.65” (WxH) or 133.5mm x 180mm x 245.5mm. The goal was to have a small footprint that doesn't extend past the base of a monitor.
Currently, it fits m-itx motherboards, itx sized (6.7") graphics card, 50mm height CPU cooler. and sfx sized PSUs.
Picture above is a real prototype. Dark banana for reference.
While it still requires a bit more fine-tuning, we hope to get some advice and comments from the community regarding our progress so far.
Thank you,
Ben Li
Thank you,
Ben Li
