Hey all,
I have a Modivio xCaseL turning up within the next couple of days and it's time to start ordering some parts. Its mainly an emulation machine so needs a CPU with high single thread performance, and the best bang for buck I can find in the UK is the i5-9400F https://www.cpubenchmark.net/singleThread.html. The question is without onboard graphics, I need a reasonable graphics card to match. Modivio recommend using a blower card to try and control temps, but I simply can't find any modern cards that are blowers.
So two questions:
1) Would it be silly of me to try and run an open-air fan cooled card?
2) Does anyone have any recommendations for blower cards at c.£200 level?
I appreciate any help that you can give.
Cheers!
So two questions:
Cheers!
