Hi folks
I'm wanting to build a SFF pc with two GPUs. I'm planning to run Windows in a VM and a 2080ti. The 2nd card will be for Linux. I want to go Ryzen as they have 12 and 16 core available. Intel is great of course because it has integrated graphics, but not high core counts. AMD also has integrated, but only on their older and low core count 3200/3400 APUs. So that options is ruled out. Reason for high core is multiple VM's and mixed gaming and workstation workloads. Something that hopefully "does it all" would be great.
Thus one idea, was to go dual GPU (non-SLI of course) with a main 2080ti for gaming (in the Windows VM) and something small and low wattage like an AMD RX560.(or something smaller and less powerful is fine too). Heck it could even be a 25TDP part. It's just gonna run 2d only anyway. This would then take the single ITX PCIe and split it into 8x and 8x - one for the 2080TI and the other for the low TDP AMD card. Was wanting to try keep the 2nd card AMD as I might do that trick to enable VRR on RTX card via something Looking Glass. Essentially copies the frame buffer from the VM to the AMD card and you plug TV into that.
Was hoping to fit this in an M1. Any idea if my plan will work?
