D
Deleted member 22799
Guest
After reading about ITX boards I left wondering for the safest bet for the smøl Dan A4. Here's an alphabetical table I made after researching all the boards, help me fill it! If you could post stuff about clearance, problems, specs and performance differences. Sources would be appreciated. Other good comparison I found.
Personally, I'm leaning towards Gigabyte for my Dan A4 V4.1 build, but depending on CPU or case you might not care about VRM or space issues. FYI, there's some old info floating around B550i not having PCIe 4.0. Also, read that X570 boards and some B550 do not support 4th gen Ryzen 5000s out of the box, so better wait until they have BIOS updated or wait for a new MB like X590. Unless you can update it yourself with an older CPU or with the BIOS update USB slot.
My current build plan is below comments are more than welcome!
It is kind of a bad time to build a computer, but unfortunately I can't wait for 6 months until price drop and new MBs/AMD AM5 to come out.
Part | Part (click for store) | Price (rounded €) | Reason |
Case | 214 | Hopefully lasts 10 years | |
Motherboard | On hold | | I'll get MB after 6800 |
PSU | Corsair SF750 | 155 | Duh! |
CPU | 320 | Smart Access Memory | |
CPU cooling | 94 | Better cooling than Black Ridge(?) and I want a challenge! | |
GPU | AMD Radeon RX 6800 | 520 (estimate) | Smart Access Memory |
RAM | 160 | Thanks to abqnm666 for info on c-die vs b-die | |
SSD | 92 | Cheap for 1TB | |
Fans | 33 | Noctua bes | |
Other | 14 | I wanna plug stuff to front USB 3.1 |
