Hello,
I would be grateful if forum members who have a B550 motherboard in their NCASE M1 could share the chipset temperatures on their motherboard, especially those with an ASUS board. Ideally in pair with temperatures from the front NVMe M.2 drive if present.
My story:
Recently I've changed my system inside NCASE M1 6.1 from Intel to AMD. I've got the ASUS Strix B550-I motherboard mainly because of forum/reddit posts saying that X570 boards have high operating temps...
The chipset on my mainboard is placed near the M.2 port at the front, the SSD is mounted directly above the chipset. As you can see from the attached screenshot the chipset temperature is quite high (~70C idle and ~80C at load – the only mobo fan is over the VRM section, near the IO ports). I assume it adds to the NVMe heat, therefore my 970 EVO at idle runs 54/63C and when I start the Samsung Magician benchmark it attains 82/117C (sic!)...
Cranking up all the fans to the max (2x from GPU, 2x from the AIO and one rear exhaust) cools it to 42/48C at idle and at full load (SM benchmark) to 68/80C, however, then my PC turns essentially into a blow dryer.
Is it normal?
Chipset starting temperature (via BIOS): 42C
After 10 minutes in BIOS: 70C
System spec:
ASUS Strix B550-I
Ryzen 5950X
64GB DDR4 3600 Mhz
Kraken X53 240mm
RTX 3070
SF750
2x Samsung 970 EVO
2x Samsung 860 EVO
+1 rear exhaust NF-A9x14 PWM slim fan
My story:
Is it normal?
System spec:
ASUS Strix B550-I
Ryzen 5950X
64GB DDR4 3600 Mhz
Kraken X53 240mm
RTX 3070
SF750
2x Samsung 970 EVO
2x Samsung 860 EVO
