Hey! Just had a quick question concerning the ASUS ROG Strix B450-I Gaming, more specifically, the Chasis Fan Header's max Amp.
I have the Raijintek Ophion ALS case and I was wanting to connect 2x Noctua NF-S12A PWM Chromax and 1x Noctua NF-A12x15 PWM Chromax
From Noctua's Website, it shows that the amp draw from the slim is 0.13 A and the two S12A's draw 0.12 A respectively.
So the question is, since the B450-I only has 1 chasis fan header, can I use a 3 way splitter to connect all 3 fans and use it on that one header without any issues? (aka what is the max Amp draw on that chasis header?)
I would prefer not to use a controller or connect the fans to a sata power cable since this is an SFF build and I want to reduce as much clutter as possible.
Also am I missing anything else? Wattage shouldn't be an issue since my PSU is a 550w right?
