CPU ASRock Fatal1ty B450 Gaming-ITX/ac & RGB + Heat issue
spongmiester
Picked up said motherboard and a FD Nano S yesterday and promptly switched over components into my new case, when i stumbled upon an issue.. I'm unable to fully use my ThermalTake fans the riing 12 Sync to be exact as there's no 12v+ RGB header on the motherboard.
So my question is what options for RGB do i have and any recommendations?
And on the heat issue.. I know one of the main issues with the Nano S is the PSU placement blocking airflow to the GPU, What's the best course of action for heat with this case, I ran No Man's Sky on default settings and my RX580 hit 80c. I followed the advice from a Reddit user and cleaned and reapplied the thermal compound on my GPU and in my old case the temps dropped by 7c but seem to be way higher in this case, so much so i'm worried to game on it in case i damage my card
