Hello wonderful SmallFormFactor Forum!
I tend to get quite a few questions from wonderful users of the Asetek 645LT, and I wanted to create a go-to place for the most common questions, as well as somewhere everyone can feel welcome to ask any question that relates to the 645LT, Asetek or even me as an Asetek employee/face of the company, in the community.
Now that we have the name and purpose of the thread explained, I'd like to take a few sentences to tell you about a specific question that got me to make this thread.
Again and again, I've been asked how much liquid is in the 645LT and whether or not it's 'safe' to bring it on an airplane. I thought about it, and figured: "what an obvious question for a SFF cooler".
So here we are!
This thread will be updated as is necessary, and I will try to keep it looking somewhat clean.
Please remember that there are no such thing as stupid questions, only stupid answer (Just made myself feel the pressure! )
AMA/FAQ:
645LT Specific
Asetek Specific
Please feel free to ask any questions or comments in the thread
/Asetek Dennis
Updated: 21-11-2019
So here we are!
AMA/FAQ:
645LT Specific
- How much liquid is in the 645LT?
- There is approximately 65ml of liquid in the 645LT. So don't worry about TSA regulations of 100ml.
- What are the dimensions and specifications of the 645LT?
- Radiator measurements are: 118 x 97 x 35mm
- Pump / Block combo: 29.8mm tall
- Pump RPM: 2800 RPM (don't worry about read-outs saying 5600RPM - it's a read out error on motherboards)
- Minimum start voltage: 8V
- Rated power: 2.16W
- Tube length: 250mm
- Supported fan size: 92mm (up to 15mm thick on the primary side - ie. under angled bends) and any on the opposite side.
- Technology: Asetek Generation 6
- Official CPU socket support: LGA 115x, 1366, 2011, 2011-3, 2066, AM4 (it will also work on other platforms with correct retention, however they are not officially supported)
- Max. operating liquid temperature: 60C
- Total weight: 465g
Asetek Specific
- Is it safe to bring an Asetek liquid cooler on a plane (will it cause leaks due to pressure differences?)
- Yes! It is absolutely safe and it won't cause a leak. The more elaborate answer is: At the surface of the earth pressure is roughly 1bar. When you're in a plane, you're obviously way above the surface of the earth, but even if you were to head to outer space (absolute vacuum) the pressure would only be reduced to 0bar. This brings the pressure difference to a total of 1bar (the parameter that determines whether or not a leak would be plausible/imminent) between the inside and the outside of the loop. All Asetek products adhere to strict certifications, one of which is UL certification. Under the approval process of getting UL certification, you (we as a company) have to prove that our products can withstand pressure tests at 3.6bar (some components as much as 9bar).
Funny side note: We regularly ship entire pallets with air freight. Nothing to worry about
- Where should I connect my AIO?
- Ideally you'll want to connect your Asetek AIO (pump connector) to the CPU_FAN port of your motherboard. This is to ensure that the pump is always running, and you'll maintain the warning features of the CPU_FAN port. Also, you won't get wrong read outs about pump speed.
/Asetek Dennis
Updated: 21-11-2019
