if anybody has the case "raijintek metis plus"
i need the measurement between the top fan mounting points and the fornt usb ports
i want to add another fan + handler and dont know if it will fit the two of them or not
the handler is 40mm wide " will mount it vertically between the 2 fans in the top"
the handler i will use
https://www.amazon.com/gp/product/B00JQYVJVK/?tag=theminutiae-20
