Any NAS Case similar to HP Microserver GEN8?
dfrgu
51
43
The GEN8 case is exactly what I'm looking for. 4 disks, one low profile PCIe, relatively compact. Any case similar to it or I will pay around 200usd to get a modded GEN8 case
ermac318
655
510
I asked this question on /r/sffpc a while back, you can see the list of cases I've found over there. If you need one LP PCIe slot, you're down to the U-NAS 410 or the SuperMicro mini tower from that list.
For what it's worth, I'm now considering the U-NAS 810A MicroATX version to transplant my Haswell desktop system into for my next NAS.
damex
30
chenbro sr301 might be worth checking out.
U-NAS cases would still be smaller.
5,861
4,916
I recently bought the Silverstone CS01-HS for a NAS/server build, though take note it's 2,5" drives only. Though it's quite small:
I'm planning on detailing the build when I have all the components, but it might take a while (waiting on Ryzen 3000 series).
wirdo
You can find that same case (taobao link above) at Inter Tech. Might be cheaper since you don’t have to import it.
It’s about 90 euros here in The Netherlands.
I’m using the Chenbro ES34169 but this has been discontinued.
