I'm about to set up a very low powered SFF build with a HDPlex 160w, but my preferred 45w AC-DC adaptor uses a 5.5mm/2.5mm DC barrel jack instead of the larger (7.4mm) one the HDPlex comes with.
My issue is that I want to build the case out of 5mm Perspex, and all the panel mounted female jacks I can see (on eBay) can only be mounted on panels up to 3mm thick.
Does anyone know of an equivalent PCB mounted 5.5mm female DC barrel I can use?
Worst case I guess I can use one of those size step up adaptors with some tape to make sure it doesn't come loose, but thought I'd ask around first.
