Power Supply HDplex Direct Plug + Brick Jack Question?
stefan33
73
24
I have
https://www.hdplex.com/hdplex-160w-dc-atx-power-supply-16v-24v-wide-range-voltage-input.html
version V2... and I read : Input Connector: 7.4x5.0mm w/center PIN,40cm Input Cable with 4PIN Molex Female
Than I can see that Dell PA-19 is compatible but on ebay I find jack Connector 9.0 x 6.2mm ?
But on HDplex site I can see that they connect the 160w direct with Dell Pa-19... So how???
Than I fouund: Dell PA-9E 240W slim that has 7,4 x 5.0.
What I have to buy? I need an adapter cable?
Have you got a power adapter from a good brand to suggest me around 160w/240w that I can direct connect to HDplex?
Many Thanks.
Or is there one cable adapter from jack to the 4 pin of the hdplex?
Thehack
Creator
Mar 6, 2016
2,779
3,592
J-hackcompany.com
I have
Many Thanks.
The HDPLEX DC-DC comes with the necessary plug to match with the external unit. Make sure your case has a cutout for it.
stefan33
73
24
Genuine DELL 240 W PA-9E you can serach on ebay or google ecc....
The Genuine should be around 70/80 USD.
