Advise for a small 1080ti case
Senaxx
26
21
Hello all, i'm Senaxx and I need some advice for buying a SFF case.
At this moment I own a huge case, the corsair obsidian 900D. It's an awesome case and it served it's purpose, but I want something different: a sff build. Problem is I own a 1080ti. The 300mm 2.5 slots ASUS ROG STRIX 1080 TI, and due this card my options are more limited in my case choice.
Personally I really love the design of the Ncase M1 v5 and while I've seen a build that has used this card the temps where very high. So I've been looking at other cases (silverstone for example) but they all aren't as pretty as the Ncase M1 (with tempered glass for example).
So i'm looking for a stylish case that would fit my Asus 1080ti. Budget isn't a problem, and if the card would fit better (or cooler) with an water cooling setup i'm all up for that.
Senaxx
26
21
So sorry! Yes, the NCASE M1, which is basically my favorite SFF chassis! At least until the NCASE M5 comes out...
If it only was a tiny bit larger ;) But a this nvidia card with EK waterblock would still fit?
Boil
1,266
1,102
Grand Junction, CO, USA
The Strix card (air-cooled) is a tight fit in the M1, but with the fittings terminal on the water block, it will not fit (too tall). I mentioned that in my original reply.
That is the problem with the taller GPUs, they usually do not fit into SFF cases. Especially when water cooled, due to the fittings terminal adding height to an already tall card.
Senaxx
26
21
So I have two choices, a different case, or buy a smaller 1080TI. What other case would you recommend?
W1NN1NG
616
532
You could look for a Dan case maybe? Idk if it would fit or not. The strix is the longest card on the market I believe so if ANYTHING you could always design your own :) check out willydijo on Google he makes some pretty cool cases you could get some inspiration from that wouldn't be difficult to do yourself
And then there's always the itx tray kit which you can get information about in the vendor section and you could build a chassis around that which would probably be the easier option
Curiosity
Apr 30, 2016
754
885
34
Florida Panhandle
it wouldn't fit without changing the cooler somehow, the A4 has a strict 2 slot limitation.
Reactions: W1NN1NG
Boil
1,266
1,102
Sorry, I would not know what to recommend for the Strix, such a large card!
All of the boutique SFF cases I have looked at (here & on the [H] SFF sub-forum) are not accommodating for such a large graphics card!
And there are not really any real SFF cases out there in the 'production' world, even the few you can find that claim to be SFF ITX cases are all usually over 20 liters in volume. And even at that point, the height / length / width of the Strix may continue to be a problem.
Or just sell the Strix & get a reference model sized card, slap a full-cover water block on it & build up a full custom loop M1 system!
