After having a bunch of different small builds (including with the Cooltek U2, M99, P-Atx V1, Sharkoon QB).
My current setup is a half broken xps15 with the compact Arous Gaming Box egpu. I decided to drop this setup since it has a bunch of issues.
So I decided to go fanless (mostly) for my next build.
The Hardware:
Edit 03/04/2021
ToDo list:
Greetings
The Hardware:
- CPU: Intel i5 10500 6/12 with 3,1ghz Baseclock I got it for a solid price (125€ shipped) It should be more than enough for me and a Intel platform has more options for passive coolers.
- Motherboard: AsRock H470M Itx/Ac It has good number of ports, BT, two m.2 slots and I got it for 105€ shipped.
- Ram: Some 16gb 2133 Kingston Kit for 50€
- GPU: MSI GTX 1660 Ventus Oc I have this card for over a year (160€ back then) it works and should have enough power for now. I am going to run it with a reduced powertarget (probably 75% maybe more) and some undervolting which hopefully combined with the new cooler should keep the 1660 cool enough.
- GPU Cooler:
Raiintek MorpheusI have seen builds with it cooling 75W GPUs passively, which of course way less than the 1660s 130 Watt. Hopefully some undervolting/reduced Powertarget it will stay under 80°C. Otherwise I am going to use Liquid Metal.Got an EKL Peter for 25€ shipped - CPU Cooler:
Silentmaxx Big Block A big 1180g Passive cooler all the way from 2010. More than enough to cool a 65w Cpu.Got an Scythe Orochi for 35€ - Storage: Intel Optane H10 1tb/32gb Got it cheap (85€ Shipped) and I was curious if Optane is any good. And a second samsung m2 ssd 512gb I got for like 40€
- "Case": Streacom BC1 mini great design, has anything I need except unimportant things like front IO or a Power/Reset Buttton. Also its pretty well Ventilated. (85€ shipped)
- PSU: Fractal Design Ion 650w Sfx-L while it is not fanless its way cheaper (85€ shipped) than the only sfx passive psu or similar solutions. The specifications say that the fans won't turn on under a 300W load, which should mean they should never turn on in this system.
Edit 03/04/2021
order the Vga Coolerrecieve all the partsassemble the buildundervolt the gpuswap the stock vga cooler- hope that the gpu does not overheat
- find a good solution for the power button
- secondary: get an infrared thermometer for some temperature readings
- secondary: either make shorter psu cables or get some shorter made to make it look a bit nicer
Greetings
