Hey Guys
Since i found this forum very helpful when i researched for my Dan A4 Build, i thought i would show my results and maybe help others.
Setup:
Case: Dan Case A4 V4
Motherboard: MSI MPG Z390I GAMING EDGE AC
CPU: Intel Core i7-9700K
CPU Cooler: Asetek 645LT + 92mm fanguard
GPU: GIGABYTE GeForce RTX 2070 WindForce - 8GB GDDR6 RAM
RAM: Corsair Vengeance LPX DDR4-3000 C15 BK DC - 16GB
PSU: Corsair SFX series SF600 Platinum
Case Cooler: Noctua NF-A9x14 PWM 92 mm - 19 dBA
Custom Cables: All PSlateCustoms.com Unsleeved cables.
M.2: Samsung 970 EVO Plus SSD M.2 2280 - 1TB
M.2 Cooler: Silverstone TP02-M2 Pasive.
My Experiences:
1. Take the time to do the job properly.
Putting the system together takes about 2-3 hours and require both patience and steady hands.
2. Get your cables right.
First i used the sleeved platinum cables from Corsair. They are thick and difficult to work with. And they are way to long, so they mess up both the looks of your system, and the airflow.
After i switched to the unsleeved custom cables and i cleaned up the rest of the cables, my CPU temperature dropped 4-5*C while running Prime95.
3. Buy an M.2 Cooler.
Before the cooler my M.2 NAND reached about 83*C while running Samsung Magician Benchmark. After the cooler was mounted the temperature dropped to a steady 69*C. The NAND Controller dropped from 108*C to 81*C.
4. Spend some time to adjust Fan- AND Pump-speed curves in BIOS. it really pays off if you would like a silent system under normal/everyday use.
5. In BIOS i have set the CPU short threshold to 105 Watt and the long time threshold to 90 Watt.
I can't see any difference in performance (maybe 1%) but the CPU temps dropped average 7*C while running Prime95.
Feel Free to ask Questions :-)
And sorry i didn't remove fingerprints from the case before taking pictures. That was sloppy of me.
/Benjamin
Setup:
My Experiences:
/Benjamin
