Hey All!
So I have a NCase M1 V6.1 running a i7 11700k with a 3080ti Asus tuff. Let’s just say “She can get toasty!”
The i7 is cooled with an EK basic 240mm aio (with Artic P12 fans) that I am quite please with the performance. However the 3080ti overclocked and undervolted is a monster! The heat this thing puts out is crazy, my deck & DAC are almost untouchable and the noise level is not great too!
So my idea is to remove the stock shroud on the 3080ti, get 120mm thin noctua fans (run them at 100% or a decent amount without to much noise) and draw the air stright from the bottom of the case (rather then have it reingest some of its waist air)
But I need some help! Does any one have any technical drawings for the Asus 3080ti? Would save me a lot of time. Will keep everyone up to date on the progress too!
