Smol X1 mini:
-3.69L (working to get it to 3.6L) I believe this is the world record currently for housing a non-lowprofile dual slot gpu with completely internal powersupply;
-dual slot GPU up to 175mm;
-39mm cpu cooler room
-flex atx psu;
-everything is internal, so no external powerbrick.
- For more frequent updates, you could follow our Instagram (SmolSFF), join our Discord server (https://discord.gg/uBXKXgM6V8), or visit our site SmolSFF.com (Mobile version is not very unusable at the moment. We are completely rebuilding it from the ground up, should be done in a few weeks).
The power button, which is a Kailh Choc white with low-profile keycap, has been moved to the back of the case, above the motherboard. This is the only place where there is enough room. For that same place, I am also designing a box to hide the leftover cables (sata and molex) from the psu. This case will be very easy to build in, and it will look very clean as the leftover cables can be hidden. It utilizes a sandwhich layout, with the Motherboard on one side (with the cable box above it), and the GPU (bottom) and Flex Atx psu (top) on the other.
Our prototypes right now are made of powdercoated steel. We're considering switching to anodized aluminium that will be sandblasted with a very high grid sand. This will make the case feel way more premium, but it will be more expensive. The screws will be countersunk on all three versions. We are also working on our very own riser cable, as the connectors on others are too bulky. A custom modular Flex ATX psu is also in the making, but it will probably never turn to reality. It would be nice though, as we'd be able to sell it at much lower prices than regular. This would allow us to release a version of the case with the psu and riser preinstalled, and the cables pre-routed (just like the NZXT H1). This can be done for around €200. Building in the case would be extremely easy and fast, which is very different than what I am used to with cases under 5L. You would just need to slot in your gpu, screw in your motherboard, and connect about 5 cables. The regular version with PCIE 4.0 riser preinstalled is will be going for between €100 and €150. Depends on the amount of orders we'd get, as the cables in small orders are quite expensive. This is why we might give buyers the option to get a PCIE 3.0 riser instead of a 4.0 one.
Here is a size comparison next to the two other cases:
- Smol X1: 6.9L, dual slot 183mm gpu, aircooler up to 126mm (with Flex Atx psu only), 120mm AIO (with both sfx and Flex Atx), SFX or Flex Atx psu;
- Smol Big X1: 10L, 2.5 slot 297mm gpu (3090 xc3), 126mm cooler room or 240mm aio, SFX psu.
Next prototypes and availability:
We are probably gonna buy the next prototypes soon. These will be very similar to the production units. There will be a custom designed product box, and the cables and powerbutton will be preinstalled. There will be a little booklet and more accesoires in the box. The next prototypes will also be made of more premium materials (aluminium) and will be anodized. At least, that's the plan. We are planning on letting in a couple interested people also buy a prototype in the next round, as this will provide early acces to some users and more feedback for us. If you are interested, let me know. If you have any questions or suggestions, let me know too.
Kind regards,
Joost Wagelaar
Edit 1: Our manufacturer recommended to continue using powder coated steel, as less manufacturing issues will exist, and the cases will feel more sturdy. This is most likely what we will do then. Probably will still order a prototype in anodized aluminium just to test.
The idea of the power supply turned out to be a bit more troublesome than it seemed. If you guys have any suggestions on some good flex psu's from companies that might be willing to work together and let me customize their product, let me know.
I am also working on one with a radiator. This means a 3.69L watercooled pc
Kind regards,
Joost Wagelaar
