I'm looking at modding my 2080 Ti with an Accelero Xtreme III.
I believe it's possible and wanted to know if anyone had answers to the following questions:
- What size spacers should be used for the cold plate when paired with the 2080 ti?
- I have a Gigabyte Windforce model, I've read conflicting information online about how they changed the pcb design since launch (mine was purchased in December 2019). Does anyone know if this will need the nv 14 connector or uses a standard 4-pin connector?
- With the correct adapters will the Windforce card definitely be able to control 2x Noctua A12 fans correctly using afterburner?
I don't want to have the fans plugged into the motherboard as mine does not have an option to base fan speed off on the GPU temp
